When the unit's cool or first turned on, it works fine. However, after 5 hrs or so the compressor cuts off until the unit cools down. Could the dual rated run cap make it do this? This particular cap's quite expensive. It's rating is 35-6/370v. Will a 35-7.5/370v one work?
Thanks,
Jim
Originally Posted by: turbopilot ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) When the unit's cool or first turned on, it works fine. However, after 5 hrs or so the compressor cuts off until the unit cools down. Could the dual rated run cap make it do this? This particular cap's quite expensive. It's rating is 35-6/370v. Will a 35-7.5/370v one work?
Thanks,
Jim That capacitor will work, however you are pointing towards a compressor problem.
note that if you have low levels it is what oils the compressor. If it is not cooling like before this could be it. As always clean the unit off.
thanks for coming our site: nike,nike shoes,jordan shoes-www.nikeok.com , best quality and customer service here!be pleased to inform you,we just updated our site products online, and now you can place order and get a good deal with discount price online, below some changes for your informations;1. all items with reasonable prices, and easy to order.2, if you order over 120usd, all items will be free shipping.3, for above 200usd order, we hv a special gifts for every packages.our shipping service as following;a. payment: Paypal/western union/money gramb. shipping way: EMS,USPS,DHLc. shipping time: about 3-5daysd. deliver model: door deliveryyou can place order online, we will get your order details when you finish order online,thanks for your time!all the bestqingcustomer service rep. nike,nike shoes,jordan shoes-www.nikeok.com
Originally Posted by: shaun rollings ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) note that if you have low levels it is what oils the compressor. If it is not cooling like before this could be it. As always clean the unit off. This has a sealed system, so low refrigerant would mean a leak. The original posted that it runs for a few hours then stops. As I stated this is the sign of compressor windings that after running, heat up,expand then cause failure :)
The 35 is the compressor, the 6 you mentioned is the fan...increasing this could cost you a fan motor. replace like for like or a 35/6 for a 35/6. Hope this helps...sounds like maybe the unit needs cleaned or the filter changed. How well is it blowing the air? That will tell you alot.
