Hopefully the attached pictures will help you. Gene.
I am going to attempt to repalce the outer door panel and panel facia to make my Bosch dishwasher match the rest of our kitchen (stainless). Do you have any tips or instructions/parts breakdown sheets that could assist me in my project? Model number is SHE43P02UC/50
-Michael
Originally Posted by: Rockjockey I am going to attempt to repalce the outer door panel and panel facia to make my Bosch dishwasher match the rest of our kitchen (stainless). Do you have any tips or instructions/parts breakdown sheets that could assist me in my project? Model number is SHE43P02UC/50
-Michael Michael, This model number does not come up. Is it American model? Gene.
Yes, bought it at Lowes I believe.
There were 3 models of the same machine and the difference was color. Mine is currently white but the black and stainless ones had a couple of different numbers where the 02 is.
Thanks Gene, do you know of anything in particular that I may need to keep an eye on during disassembly or reassembly?
While lowering my Bosch shx46L15UC Dishwasher door, something snapped. it no longer lowers gently. Is this an easy fix? Is it a spring?
Help please....
Remove the bottom panel and inspect the door springs and the tension cables (#5 & #7 on the diagram). If any of them is broken the dishwasher has to removed from the cabinet for repair. Gene.
