:( Just replaced the control assembly in the washer, all nine of the green indicator lights are blinking. The washer will not run, nothing else works.
On the old control there was a plug with a jumper wire. This plug is the model select plug and it doesn’t connect to anything on the washer so people often leave it off. If you leave this plug off the lights on the control will blink as you describe. Hope this helps! Clothes Washer Repair Guide
Originally Posted by: applianceman  On the old control there was a plug with a jumper wire. This plug is the model select plug and it doesn’t connect to anything on the washer so people often leave it off. If you leave this plug off the lights on the control will blink as you describe. Hope this helps! Clothes Washer Repair Guide Your right, I figured this out on Saturday, thanks for the reply.
Originally Posted by: Buda  Your right, I figured this out on Saturday, thanks for the reply. Thanks! It worked. That mystery piece was on the old board, took it off, lights are gone and washer working. Thanks again. Joe
