czina27
#1 Posted : Wednesday, September 8, 2010 10:25:24 AM(UTC)
czina27
the handle broke off the door and there are two existing screws in place...how do you remove them and install the new handle?
Joe / APP Team
#2 Posted : Wednesday, September 8, 2010 11:05:13 AM(UTC)
Joe / APP Team
Czina,
Here is your part number
Part number: AP3178131
And here are the instructions for dismantling the door, so you can access the screws and replace the handle.
Good Luck,
1. Unplug microwave oven or disconnect
power.
2. Open the microwave oven door.
3. Pry the choke cover away from the top
door pin, and remove the top pin from the
pivot bracket. Lift the door off the bottom
bracket, and remove it
4. Place the oven door front side down on a
padded surface.
5. Remove the choke screws from the door
frame.
6. Starting at the top right corner (see the
round inset photo in the left column), pry
the choke cover out with a putty knife,
and unsnap it from the choke. Only remove
the top, bottom and right sides of
the choke cover at this time. You will remove
the handle end of the choke cover later.
7. Starting at the top edge of the door near
the center and working clockwise, use a
putty knife, and pry the latching tabs of
the choke out of the door frame slots. Lift
the choke as you release the tabs so they
do not snap back into the slots. NOTE:
When you reach the handle side of door,
pull both the choke and the choke cover
away from the door frame, and then separate
the two components.
8. To remove the door switch actuators from
the choke, remove the screw from each
actuator.
REASSEMBLY NOTE:
When you reinstall
the door on the oven, insert the top pin into
the pivot bracket and press down on the pin
until it snaps into place
czina27
#3 Posted : Wednesday, September 8, 2010 11:34:21 AM(UTC)
czina27
will use your notes to replace the handle once I review the part
Joe / APP Team
#4 Posted : Wednesday, September 8, 2010 11:54:05 AM(UTC)
Joe / APP Team
OK,
Drop us a line when you're through, and let us know how you did.
Good Luck,
dgdl441
#5 Posted : Tuesday, September 14, 2010 3:39:46 AM(UTC)
dgdl441
Online shopping has been a trend now, so if you want to buy cheap boots isn`t a problem. The important question is what kind of boots style you like, in order to show it in front of your loved person? If so, the best quality and cheap boots is essential. our company Ugg boots not only beautiful but also very good quality,that is why in winter, best choices for women boots must be ugg boots. So where can buy best quality and cheap ugg boots. It is the focus of this article. First of all,the Internet so developed, it is also more stores of ugg boots will dazzling you, right? So hard to get one pairs nice boots to fited yourself. You have to sure your size, color, or even boot`s weight you have to consider too. When you think about the appearance of the boots, then you can start shopping. Here in ugg,ugg boots,cheap ugg boots,ugg boots online-www.ugg5803.com you can find all the newest ugg boots, and sizes are also able to choose, as long as you know your size. If you want to get big quantity of ugg boots or wholesale ugg boots,you also can choose from ugg,ugg boots,cheap ugg boots,ugg boots online-www.ugg5803.com. All the ugg boots are designed by the designer, using a high-grade suede material. Also ugg boots been made exquisite, so it can been a birthday gift or Christmas gift too !Their contact email is:service@ugg5803.com.
Guest (4)
