ssmueller
#1 Posted : Monday, September 13, 2010 6:34:50 PM(UTC)
ssmueller
Not sure what is going on with the frig, it keeps freezing which causes the water dispenser lines to freeze up as well. We've cleaned the coils on the bottom of the frig and it is still freezing! We are trying to figure this out on our own to avoid a service call. Any advice?:confused:
dgdl441
#2 Posted : Monday, September 13, 2010 9:42:56 PM(UTC)
dgdl441
Online shopping has been a trend now, so if you want to buy cheap boots isn`t a problem. The important question is what kind of boots style you like, in order to show it in front of your loved person? If so, the best quality and cheap boots is essential. our company Ugg boots not only beautiful but also very good quality,that is why in winter, best choices for women boots must be ugg boots. So where can buy best quality and cheap ugg boots. It is the focus of this article. First of all,the Internet so developed, it is also more stores of ugg boots will dazzling you, right? So hard to get one pairs nice boots to fited yourself. You have to sure your size, color, or even boot`s weight you have to consider too. When you think about the appearance of the boots, then you can start shopping. Here in ugg,ugg boots,cheap ugg boots,ugg boots online-www.ugg5803.com you can find all the newest ugg boots, and sizes are also able to choose, as long as you know your size. If you want to get big quantity of ugg boots or wholesale ugg boots,you also can choose from ugg,ugg boots,cheap ugg boots,ugg boots online-www.ugg5803.com. All the ugg boots are designed by the designer, using a high-grade suede material. Also ugg boots been made exquisite, so it can been a birthday gift or Christmas gift too !Their contact email is:service@ugg5803.com.
#3 Posted : Tuesday, September 14, 2010 2:49:50 AM(UTC)
Replacement parts for MAYTAG MSD2656KGW Ref - SXS/I&W | AppliancePartsPros.com
Here is a manual
http://www.servicematters.com/maytag_library/docs/16025628.pdf
First I would check the freezer temperature, just to make sure it is not too cold. Should be between 0 and 5 degrees F.
The fresh food side is controlled by the damper (Item 7 in Section 3).
Check that it opens/closes with changes to the fresh food set temperature.
Could be the damper itself, the fresh food thermistor or the control board.
Most units have a lower vent between the fresh food and freezer sides.
If yours does make sure that it is clear.
It could be that there is not proper air circulation and you do not open up the fresh food door that often so the fresh food side is loading up with cold air.
Note: I could not find a vent in the parts breakdown so your unit may not have one.
