2 Pages<12
#11 Posted : Monday, September 13, 2010 1:45:55 AM(UTC)
Here are your parts, includes the wiring layout.
Replacement parts for JENN-AIR JCD2290HES Ref - SXS/I&W | AppliancePartsPros.com
Problem may also be on the control board.
Check your voltages there.
dmeredith@rocketmail.com
#12 Posted : Monday, September 13, 2010 12:47:54 PM(UTC)
Thanks guys. Not sure about the lose wire, as I get a constant 110V when I connect the multimeter to the fan motor harness (motor NOT connected).
I ordered a new controllerboard, hopefully that will correct the problem, I will keep you posted. Thanks again for your help!
David
#13 Posted : Wednesday, September 15, 2010 5:40:48 PM(UTC)
As an update, the new controller board fixed my fan problem. Readings at the fan motor harness with the new board were 119V and 3.3 Ma. Thanks for all your help.
David
2 Pages<12
