ddlong
#1 Posted : Monday, September 13, 2010 9:32:25 AM(UTC)
ddlong
When finished using oven and the timer, a short while later the"beeping starts" and I get fault F 10. What is causing this? What part is needed? I tried turning off the breaker for awhile and even pushed "reset" but problem still exists.
Joe / APP Team
#2 Posted : Monday, September 13, 2010 12:44:42 PM(UTC)
Joe / APP Team
DD,
The F10 code on your unit indicates a bad oven temperature sensor.
Part number: AP3969435
Did this start occurring after a self clean cycle ?
Did you notice if you had any overheating, cooking problems ?
have you got tools and a meter to access and check the resistance of the temp. probe ?
:cool: :cool: :cool:
Joe / APP Team
#3 Posted : Monday, September 13, 2010 1:10:36 PM(UTC)
Joe / APP Team
DD,
Based on the manufacturers information,
You most likely have a bad oven temperature sensor
Guest (5)
