I ordered a new plastic door latch from you . I don't see how the door comes apart to install the new latch.Could you please help?
Jerry
Hi Jerry, Unfortunately I'm not very familiar with this dryer. Maybe somebody else on the forum can help you better. Here are the break down diagrams for the Bosch dryer Model WTA3500 UC/04Gene.
Jerry:
Did you ever find an answer to this question? I have the same problem with mine. It just broke this morning.
From what I've been told (I have yet to have to do this myself) the outer door will unsnap from the inner door. Once this is done, you can get to the screws which secure the latch arm.
KC
Originally Posted by: Servicer  From what I've been told (I have yet to have to do this myself) the outer door will unsnap from the inner door. Once this is done, you can get to the screws which secure the latch arm.
KC Thanks. I will try that. For now super glue is holding it together.
