Im trying to install a new control board to my dryer, the board has been updated so it looks different. any tips on how to install it. If it is even the right board?? HELP PLEASE!!!! Thanks. Tisha
Originally Posted by: tishalicious13  Im trying to install a new control board to my dryer, the board has been updated so it looks different. any tips on how to install it. If it is even the right board?? HELP PLEASE!!!! Thanks. Tisha Tisha, Yes, The control was updated and will look different, due to the engineering change( PC control re designed to operate in both versions of that unit). But everything else is the same (same connectors, wires, and mounting procedure). *** Turn off power or unplug line cord from outlet. *** Access to the control board is achieved by, removing the 1/4" screws(4) across the top back portion of the control panel and lean the control panel forward from the top. Disconnect the the touchpad ribbon from the control board connector, remove the (4) 1/4" screws mountig the contol board to the console and move control board out of the way. Mount new control board, now install wiring connector one at a time, on the same labeled connector on new board as off the old control board, install touchpad ribbon. Reverse procedure to install control console and test operation. Good Luck, :) :) :)
