I have a maytag washer that doesn't always spin out properly. When it gets to the spin cycle, a burning smell comes from the motor. If I turn it off and let it cool down, when I turn it on it spins out fine. This mostly happens on the last spin, not the first one.
Yesterday I ran it empty several times and it made it through each time, but it still smells hot in the motor area. When it spins, it seems to spin freely. There doesn't seem to be anything wrong with the belts or couplers.
This washer has been stored in a barn for a few years and there is some evidence of rust around the motor.
Obviously I think it is the motor, but I'm wondering if someone thinks I've missed something.
Remove the belt(s) and run it with no load. If the motor will get hot or warm - replace it.
