Hive
#1 Posted : Friday, September 10, 2010 8:17:35 PM(UTC)
Hive
The washer fills and drains but it won't spin or wash. The timer gets stuck at 1 minute remaining. The door switch is working.
What part mostly likely failed? The motor? The control board? A lose wire?
sidfink43
#2 Posted : Sunday, September 12, 2010 10:56:28 AM(UTC)
sidfink43
There are a couple of candidates here. Use this service manual to try and troubleshoot thing.
http://www.servicematters.com/m...ibrary/docs/16010061.pdf
Your model is discussed in detail at the back of the manual.
