Elisa
#1 Posted : Tuesday, July 15, 2008 6:17:22 AM(UTC)
Elisa
My Bosch diswasher is leaving particles and grit everywhere...even the door. It runs it's cycle (although noisery than usual). The washer goes through it's cycle, and the sand-like grit and particles are baked on. Any suggestions? I've checked the filters and cleaned them to the best of my ability.
#2 Posted : Tuesday, July 15, 2008 4:45:38 PM(UTC)
Is there enough water?
The model number you posted is incomplete.
Elisa
#3 Posted : Tuesday, July 15, 2008 5:34:32 PM(UTC)
Elisa
The model number is SHX46A0Suc/14
fd8407 00150
How does one check if it is getting enough water? I put it on regular or heavy cycle. I've checked the filter and jiggled the hose going under the sink.
Thanks!
#4 Posted : Wednesday, July 16, 2008 3:48:59 PM(UTC)
The water should be about 1 1/2" above the floor.
