firest02
#1 Posted : Friday, September 10, 2010 5:11:22 PM(UTC)
firest02
Have a Electrolux dryer Model # LEQ2152ES0 front loader. The problem is it will start for about one second then shuts down. The displays reads PF. Thanks for any info!
ForeverLawst
#2 Posted : Saturday, September 11, 2010 4:35:00 PM(UTC)
ForeverLawst
I've got the same problem with my Frigidaire gleq2152es0.. most likely the same dryer =)
My husband replaced both the heating coil assembly and the thermal limiter with no luck. We replaced the control board a couple months ago for a different problem (stuck button error) so, I'm really hoping we don't have to replace that again.
It will run full cycle when on the air-only setting, but anytime we try to start it while in a heating cycle it kicks in for 1/2 to maybe 2 seconds.. and then resets.
Looking forward to any help on this problem.
-Marci Bork
