WASHER SPINS BUT ALL THE WATER DOES NOT DRAIN OUT ALSO THE BELT SMELLS LIKE ITS BURNING .WHEN I PUT THE DRAIN HOSE DOWN LOW IT DRAINS BETTER BUT STILL LEAVES THE CLOTHS- WET.:confused:
Need your model # to help. Sounds like your separate drain pump has stuff in it, just pull hoses and clean out.
