jordand
#1 Posted : Tuesday, July 15, 2008 12:36:34 PM(UTC)
jordand
I've looked all over for a model number on my oven, and I can't find it. It is a gas stove, and all of the top sections lights fine. It's just the oven that doesn't light. When I turn the dial I see some sort of element light up, and can smell a little bit of gas, but it doesn't light. I even tried to use a lit match and it still won't go. Is the gas line clogged somehow?
#2 Posted : Wednesday, July 16, 2008 12:02:05 PM(UTC)
Most likely the problem is a bad oven igniter. For more accurate advise we need the complete model number of the unit. You can find it under the top panel, on the oven door frame or on the frame behind the bottom drawer.
