amyhill007
#1 Posted : Wednesday, September 8, 2010 8:39:47 AM(UTC)
amyhill007
I need help figuring out what exactly I need to order. I have a picture of the part that is broken. The description would be it is the arm that holds the wheel that rests on the drum. The arm is broken that holds up the wheel.
#2 Posted : Wednesday, September 8, 2010 11:22:52 AM(UTC)
I'm afraid I did not get clear what is wrong with your dryer. Can you refer to the numbers from the diagrams?
Here are the breakdown diagrams and Replacement parts for MAYTAG SDE305DAYW Dryer - Ele | AppliancePartsPros.com
amyhill007
#3 Posted : Wednesday, September 8, 2010 11:43:44 AM(UTC)
amyhill007
That is the problem I believe that it is part 15, the arm, but I am not sure. I tried to up-load a picture of the part but it kept coming up with an error. The drier had always made a noise and we took it apart when it completely stopped working. The arm that is underneath the drum of the dryer is broken and I need to know the exact part for us to order.
#4 Posted : Wednesday, September 8, 2010 1:38:35 PM(UTC)
Please click on the diagrams link and provide the reference number for this part.
P.S. Most likely the problem with a picture you are having is due to its size. Try to compress it.
amyhill007
#5 Posted : Wednesday, September 8, 2010 3:58:44 PM(UTC)
amyhill007
I compressed it and it is still too big. Argh! The part # is AP4047170. It is the pully system that is under the dryer drum.
#6 Posted : Thursday, September 9, 2010 8:12:49 PM(UTC)
I'm glad you were able to find the correct part number.
