timbaker
#1 Posted : Thursday, September 9, 2010 11:37:18 AM(UTC)
timbaker
Our Amana Big Oven Gave an F2 error and got very hot. I had to turn the breaker off because the oven would not cool down when powered. Now, when I turn the breaker back on the oven turns itself on again with the temperature set on off. Do I have a bad Temp Sensor or a bad ERC board?
Thanks!
#2 Posted : Thursday, September 9, 2010 2:56:34 PM(UTC)
Most likely the problem is a bad ERC. The overlay is no longer available and you should be very careful not to damage the old one while removing and reinstalling it.
- The ERC Part number: AP4104316
timbaker
#3 Posted : Thursday, September 9, 2010 4:42:03 PM(UTC)
timbaker
Thanks Gene,
I have a temp sensor on the way since I suspect that's what caused the oven to overheat in the first place. I'll order the ERC tomorrow. Is there a place online where I can find directions for replacing the part? I don't need specific directions, just a general guide. Thanks!
#4 Posted : Thursday, September 9, 2010 9:03:27 PM(UTC)
You are welcome.
In order to replace the ERC just remove the rear panel. Do not replace the sensor yet - I don't think it will solve the problem.
