hpad06
#1 Posted : 15 years ago
hpad06
My dishwasher does not dry completely, so I opened up the bottom inside and finds there is water left there. dishwasher still washes and heat up and I see the pump can get water out however the water will flow back.
I took a picture of the water
pic1 | Flickr - Photo Sharing!
Any suggestions?
hpad06
#2 Posted : 15 years ago
hpad06
any suggestions?
LoveLearn
#3 Posted : 15 years ago
LoveLearn
I'm not going to type this again, so I suggest that those dealing with partially-performing dishwasher draining systems read this:
http://forum.appliancepartspros...ll-water.html#post268611
Good luck,
John
hpad06
#4 Posted : 15 years ago
hpad06
Thanks John!
This is the link to my dishwasher manual:
http://manuals.frigidaire.com/p...df/Kinston/154737301.pdf
I can't seem to find water valve for draining, in my case, is it integrated in the drain motor, do I need to replace drain motor?
Thanks a lot!
