idflyfisher
#1 Posted : Monday, September 6, 2010 10:05:15 AM(UTC)
idflyfisher
Happy Labor Day!!! (GO BSU :) )Laboring on the dryer at home. Just died. No sound other than the timer when the unit is plugged in. Have learned much about how to use a voltage meter and have gone through the power and switches. It all checks out with the exception of two wire connections on the timer. According to the legend on the wiring diagram I should have a closed circuit when reading T-W but it is open in all cycles. Have I found the culprit?? I would like someone with more knowledge than me to confirm before I order the part. Thanks in Advance
#2 Posted : Thursday, September 9, 2010 5:53:02 AM(UTC)
Yes you are correct that it should be closed (0 ohms).
