Electric dryer heat poor - takes 2 cycles to dry nomal clothes batch (no big or dense/heavy items,just socks, shirts and the like).
Looking at manual, I didn't see a heater or element, but did see a thermostat and a thersostat heater. Since system still works, how can I identify weak part?
Checked lint filter and exhaust system - seem OK - no moisture sensor.
Thoughts/suggestions?
The main cause of your problem is an obstructed air flow. This means you will need to open it up and clean it out, from the outside vent all the way through the machine. Also, check the fan to see that it is blowing at the correct speed and is not loose on the shaft or has some other problem.
