2 Pages<12
nursenorris
#11 Posted : Wednesday, September 8, 2010 10:57:27 AM(UTC)
nursenorris
:D After finding & reading this trash compactor problem I'm happy to report I was able to diagnose the same exact problem with my compactor & it is now working again. Thanks
monicakm
#12 Posted : Wednesday, September 8, 2010 11:05:00 AM(UTC)
monicakm
Glad it's working again but our fix was short lived. We had to replace the part. Part was $60ish and was very simple to replace. Good luck!
Monica
nursenorris
#13 Posted : Wednesday, September 8, 2010 11:14:22 AM(UTC)
nursenorris
monicakm I should have elaborated that I had to order a replacement part also at $108 before the problem was fixed.
issama
#14 Posted : Tuesday, November 9, 2010 2:58:15 AM(UTC)
issama
Most likely the problem is a bad push-button switch on the control panel.
You have to remove the container and the two screws on the bottom of the control panel. Pull the control panel up to release it from the tabs and it's all yours.
- The part number for the push-button switch is AP3084656
Here are the break down diagrams for the Whirlpool trash compactor Model GX900QPKB0
HEY GENE, I DID ALL THE ABOVE RECOUMENDATION, I TOOK IT A PART AND ORDER AND INSTALLTHE SWITCH , I TURN POWER BACK ON AND TEST THE SWITCH. IT ISN'T COMING ON. HELP PLEASE. WHAT A I DONG WRONG? FYI; I RECONNECTED ALL THREE WIRES THE SAME EXACT WAY THEY WERE .. HELP PLEASE
#15 Posted : Tuesday, November 9, 2010 12:31:48 PM(UTC)
What was the original problem?
What is the complete model number of the trash compactor?
2 Pages<12
