I have a maytag neptune washer that is about 2 years old. recently the machine gave an error code "Hr". In my manual it states that this is a heater relay failure. It suggest replacing the control board. I purchased a new board and after installing it, the machine worked fine for 3 loads of laundry. The machine has started giving the same 'Hr' code again. I have a replacement board on the way for my new one, but I want to make sure there isn't an underlying problem that is making the control board short out. Is there any way to test the wiring harness to see if that maybe part of the problem. I do not want to install the new board only to have it fail again. I have had a repair person out to look at the machine. He did not find anything wrong with the machine at the time. (This was before I recieved the new control board.) He did check the thermostate and that checked out fine. (I dont know if that has any relavance to this problem.) Any suggestions would be greatly apprieciated. Thank you.
I have Maytag Neptune front loading machine with a hr error code i just recently replaced the control panal what is the meaning of the hr code,please advise
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Op error code on my Maytag Neptune washer. The lid will not unlock.
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 ![United States United States](/Content/images/flags/US.png) Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
