I need some parts for the ice dispenser in the door. How do I remove the front cover assembly for the ice and water dispenser?
Thanks for the help
My Whirlpool has a slightly different model number ED25DQXDN05 made in 04/97 The panel moves right to left or left to right a little when you push on either side of it means it is not screwed in from the back side. This means that if you pull on the left side of the panel in the center outwards and put a flat head screw driver under it and pull down on the whole panel sliding the screw driver downwards the outer of the two bottom clips will let go. The other clip will let go and you can then pull the panel down from the bottom. There are three up clips that are longer on the top part which would break off if you would try prying from the top to begin with. Then once removed there are three screws holding a smaller panel on. Hope this helps!:)
