DADZ55
#1 Posted : Wednesday, September 1, 2010 5:52:25 PM(UTC)
DADZ55
Electric dryer won't start without assistance by turning the drum, then operates fine. I followed advice on previous posts with no luck. Should tension on the belt be adjusted? If so, how? How can I check to see if felt or other items obstructing drum? Suggestions would be appreciated.
sidfink43
#2 Posted : Sunday, September 5, 2010 3:42:50 PM(UTC)
sidfink43
The symptons indicate your motor is failing. Your better decision may be replacing the machine.
SublimeMasterJW
#3 Posted : Sunday, September 5, 2010 3:53:44 PM(UTC)
SublimeMasterJW
