bccavanaugh
#1 Posted : Friday, September 14, 2007 9:50:18 AM(UTC)
bccavanaugh
True age unknown. Just moved in. Electric oven was working fine till yesterday. The right main oven stopped working (both top and bottom elements not working, bulb doesn't turn on when oven door opens, when dial turned to set bake temp. the indicator light doesn't turn on). The left, small oven works as well as the top 4 range burners.
Serial number: E247865
Thanks for any help, input or suggestions.
Brett Cavanaugh
#2 Posted : Saturday, September 15, 2007 9:22:30 PM(UTC)
Hi bccavanaugh
If you can make a pictures of the range and the control panel and post them I might be able to help you.
