glennb100
#1 Posted : Friday, July 11, 2008 8:01:07 AM(UTC)
glennb100
One burner will not turn off. It stays red hot. When on high, it gets more red than it should. everything else works fine. any ideas on the part needed?
glennb100
#2 Posted : Friday, July 11, 2008 9:13:49 AM(UTC)
glennb100
is there a way to safely unplug this burner or controller so I can use the other burners?
abadfish66
#3 Posted : Friday, July 11, 2008 9:50:28 AM(UTC)
abadfish66
Your switch is bad and needs replacing. You can disconnect the power wires to that switch, should be 1 red, and 1 black. remove them from the switch, cover the ends in electrical tape so they dont short, and the rest of the burners will work.
