AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Speed Queen dryer will not shut of in automatic mode
My speed queen dryer will not shut off in automatic dry mode. The "timed" dry works fine. I'm thinking it may be one of the sensors but don't know which one. There are 2 sensors on the heating element assembly. Is there a way to check the sensors or what one do I replace?
Here are your parts Replacement parts for AEM633W models | AppliancePartsPros.comI cannot find a wiring diagram for this unit so am doing a bit of guessing. The two sensors on your heating element are a hi-limit thermostat and a thermal fuse neither will cause your problem. The main control thermostat is mounted on the blower assembly (Item 19 in Section 8). Here is the guess part. On most units in timed dry the timer motor gets power directly from one side of the line. In auto modes it gets power when the heater is turned off by the main thermostat. It looks like your main thermostat has 3 connectors. If yes, one will be a common. One will be normally closed, this is the contact that gives power to the heater. The last will be a normally open, this gives the power to the timer motor when the heater is switched off. Odds are that it is this thermostat that is faulty. Since I am guessing, please confirm that yours is a 3 contact thermostat. There is also a possibility that you have a grounded eement re: the element has sagged or broken and is touching the case. Sometimes this can result in the heater always being on at a low heat and therefore the thermostat never opens. I doubt thuis as you said that timed dry runs normal. |
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
