Rayken
#1 Posted : Friday, September 3, 2010 10:07:12 AM(UTC)
Rayken
This unit bahaves as follows:
You can select a bake function and enter a temperature for the preheat. The element comes on and preheat commences, then the the bake program (that has been selected) disappears and the clock reverts to time of day and the oven shuts off. It's as though you had hit the cancel pad except there is no corresponding beep to denote entry of the cancel button.
After trying several times the oven may go ahead and heat normally or it may shut off during use. There are no beeps, as would be heard if the clear pad was shorting.
Rayken
#2 Posted : Thursday, September 16, 2010 2:22:10 PM(UTC)
Rayken
I see that no one has responded to this querrie. Isit that odd a problem that no one has seen it?
Dacor Wall Ovens -- Need help with replacing hinges (Oven Repair (including Ranges and Cooktops))
by MCLP 8/3/2014 9:24:29 AM(UTC)
dacor wall oven malfunction (Oven Repair (including Ranges and Cooktops))
by cjargo72 4/11/2012 8:30:49 PM(UTC)
dacor wall oven (Oven Repair (including Ranges and Cooktops))
by george frisch 12/2/2008 8:34:29 AM(UTC)
Dacor wall oven - fails preheat (Oven Repair (including Ranges and Cooktops))
by ericrah 10/3/2008 10:25:41 AM(UTC)
