greencraig
#1 Posted : Thursday, July 10, 2008 6:16:48 PM(UTC)
greencraig
My range oven burner never ignites. All the other burners including the broiler and stove top burners light and work fine. When I turn the oven on, I hear the fan start, the igniter lights up, but I don't hear the gas flowing. When I started troubleshooting, I noticed sometimes when I moved the Valve & Regulator assembly it would sometimes start. I assumed it was a bad Valve & Regulator assembly so I ordered a new one from appliancepartspros and put it in. It is still doing the same thing. Any idea what it could be? Thanks
#2 Posted : Friday, July 11, 2008 12:54:11 PM(UTC)
Most likely the problem is a bad oven igniter.
- The part number for the oven igniter is AP2994573
Here are the break down diagrams for the Kitchen Aid range Model KGRT500FWH1
greencraig
#3 Posted : Friday, July 11, 2008 3:28:28 PM(UTC)
greencraig
Thanks for your help, how can I be sure it is the igniter? I already wasted $100 on the valve assembly, I do not want to spend another $70 on igniter unless I can be sure.
#4 Posted : Friday, July 11, 2008 3:45:10 PM(UTC)
You have to have a special meter to measure current drawn by the igniter. Normally it suppose to be more than 3.2 amps.
LoginFreak
#5 Posted : Friday, July 11, 2008 4:19:16 PM(UTC)
LoginFreak
Like Gene said.
If it has 3.2 amps draw then it should be good.
But looking at it is the easiest way.
If it's white in a certain place or all white.
Then it's bad.
I would have to say 90% of the calls on gas ranges are Igniters.
greencraig
#6 Posted : Saturday, July 12, 2008 5:35:10 PM(UTC)
greencraig
I just tested the amp draw through the wire connected to the valve assembly and it was 2.59 amps. I'm going to order a new igniter. Thanks for y'alls help.
greencraig
#7 Posted : Wednesday, July 16, 2008 4:24:53 PM(UTC)
greencraig
I just got the igniter in and replaced it. It worked! I'm very impressed with this site and will recommend to my friends. Thanks for your help.
BTW, anyone need a valve and regulator assembly? It looks like it fits multiple models.
Kitchenaid Gas Range KGRA806PSS00 (Oven Repair (including Ranges and Cooktops))
by bobr55 2/16/2024 1:31:09 PM(UTC)
Kitchenaid Gas Range / Oven Panel Off - No Power (Oven Repair (including Ranges and Cooktops))
by Rsundy 8/4/2020 4:26:47 PM(UTC)
Kitchenaid gas range power burner control knob doesn't turn past Lite (Oven Repair (including Ranges and Cooktops))
by dathinker 9/9/2013 9:31:18 AM(UTC)
Help to reinstall kitchenaid gas range door KGRS807 (Oven Repair (including Ranges and Cooktops))
by pafnucy 1/16/2011 4:35:39 PM(UTC)
Kitchenaid gas range - OFF button not working (Oven Repair (including Ranges and Cooktops))
by Streuf 12/28/2009 12:00:32 PM(UTC)
Kitchenaid Gas Range Door Handle loose (Oven Repair (including Ranges and Cooktops))
by y1jmg 10/24/2009 11:51:01 AM(UTC)
KitchenAid Gas Range will not get hot (Oven Repair (including Ranges and Cooktops))
by Saw Man 6/15/2009 5:07:02 AM(UTC)
