hello, My Machine Fills But Will Not Spin Or Do Anything Sometimes Just Heard Buzzing Noise,though Not Very Loud Entire Thing Is Disassembled Now Thought Could Be Motor Coupler But Seemed Fine , Motor Still Seems To Work As It Spins Both Ways, Not Super Easily Though. If I Need To Replace Motor I Will Just Throw, Wish I Could Just Fix Since Apart And Just Got Newborn And Sure Should Be Cheaper Then Asking Price Of New Motor.thanks To Anyone Who Can Offer Advice.georgieboy
Does the washer agitate in wash mode.
There is no agitation at all, I had to drain manually.
Your timer might be bad if some current is going to the motor. Pull cover off timer, if it has one and check contacts.
