2 Pages12>
wallyz
#1 Posted : Monday, August 9, 2010 12:20:36 PM(UTC)
wallyz
The igniter on my gas stove top will not stop sparking. I had to unplug the unit and now I have to use a match to light the burners. What could cause this?
#2 Posted : Monday, August 9, 2010 2:20:56 PM(UTC)
Most likely the problem is a shorted or broken one of the ignition switches. A visual inspection can help to find a physically broken switch. If it's shorted, it has to be tested for continuity.
- The ignition switch Part number: AP4101565
macpete
#3 Posted : Thursday, September 2, 2010 5:35:17 PM(UTC)
macpete
I have the opposite problem on a Magic Chef stobve (8114P627-60). The most used burner takes a bit longer to light the gas because of a irregular/weak spark (as compared to the others). How do I fix this, how do I get into/under the top burners?
Thanks,
Macpete
#4 Posted : Friday, September 3, 2010 7:39:18 PM(UTC)
Very likely the problem is a bad burner igniter.
The model number you posted is incorrect. Verify and repost it please.
macpete
#5 Posted : Saturday, September 4, 2010 6:00:06 PM(UTC)
macpete
The Model number is CGR3740ADW, I still dont know how to get at the burner igniter
#6 Posted : Monday, September 6, 2010 1:54:32 PM(UTC)
You have to turn the burner CCW and pull it up. The igniter is attached to the burner and it comes as a part of the burner.
- The burner assembly Part number: AP4394705
macpete
#7 Posted : Tuesday, September 7, 2010 9:01:11 AM(UTC)
macpete
Fantastic, I ordered the part today!
Thanks,
Mac
macpete
#8 Posted : Thursday, September 9, 2010 9:02:34 AM(UTC)
macpete
Thanks,
Maytag
Dam, I just got the new part, installed it and the spark is still not a regular spark as the other burners :( Is there a electronic control box of some kind that the two wires come from, could it be defective in some way?
-Macpete
#9 Posted : Thursday, September 9, 2010 9:00:29 PM(UTC)
Swap the igniter wires between this and any other properly working burner close to that one. See how they work and post the results. Post the serial number of the range.
macpete
#10 Posted : Friday, September 10, 2010 7:59:04 AM(UTC)
macpete
Did that and the igniter using the new wires worked correctly, this tells me that its not the igniter itself thats defective.
Serial number is 13035335UY
Thanks.
Mac
Maytag Double OVen Model MGR6875ADW- Igniter wont stop ticking (Oven Repair (including Ranges and Cooktops))
by gnieciag 10/15/2023 1:53:42 PM(UTC)
Igniter wont stop ckicking (Oven Repair (including Ranges and Cooktops))
by themcnabs 9/17/2013 2:50:35 PM(UTC)
2 Pages12>
