Originally Posted by: jbueker
Hey there. First of all ... love this site. Ok ... the pull start / push stop knob comes all the way off. Part # AP3738284 shows a little "piece" in the center of the timer contol arm which I am missing. This looks like a piece that would keep the knob from coming off? Can this piece be replaced separately from the whole timer? THANK YOU!! - Jeff r
Jeff,
You may need a new timer(the part number you listed).
If that tab is missing you will need it, the timer is a "sealed" unit, and can't be repaired.
Here's some basic access information for you :
Servicing Components in the Console
1. Remove the two phillips head screws securing the front corners of the
console to the washer top.
2. Tip the console back on the hinges that secure the top of the console to
the washer back panel.
Removing the Timer
Plastic Body
1. To remove the timer knob, push he knob in from the front
2. At the back of the timer, pull the black tab out approximately 3/16",
then pull the timer knob off the shaft.
3. Slide the timer dial from the timer hub.
4. Unplug the wiring harness from the timer assembly terminals.
5. Remove the one(1) hex head screw securing the left side of the timer
assembly to the console mounting plate. Then lift the left side and slide
and slide the tabs at the right side of the timer assembly from the
console mountig plate.
I'm sure you don't need to do every step, at this point, but get to the back of that timer and check the black tab in the dial shaft opening, and see if you can get it into position to hold your knob , or if it fell out, or something like that,
You may be able to get something going for a while, until you have to replace the timer.
Good Luck,
