Tony Wells
#1 Posted : Tuesday, August 31, 2010 4:58:41 AM(UTC)
Tony Wells
Have this Maytag dryer and everytime I turn the machine on it has this loud grinding / rumbbling noise coming from the motor area. Any idea what is happening to my dryer?
#2 Posted : Wednesday, September 1, 2010 4:04:15 AM(UTC)
Replacement parts for MAYTAG PDET910AYW Dryer - Ele | AppliancePartsPros.com
Here is a manual which should help sort this out
http://www.servicematters.com/maytag_library/docs/16026315.pdf
Could be something has dropped into the blower wheel or the wheel may be loose on the shaft. Could even be that a motor clip has come loose.
Other possibilities would a a bad belt, idler wheel, rear support roller, front glides (drum supports) or the motor itself.
While you are at it, would be a good idea to check/clean your vent system.
Noisy motor problem (Refrigerator & Freezer Repair)
by KantSleep 5/16/2011 12:28:21 PM(UTC)
Noisy Motor - Sqealing (Dryer Repair)
by apd129 4/15/2009 6:02:14 PM(UTC)
