After closing the door and hearing it clicked closed, it will not turn on when you hit the start button. It does have power and the breaker is not tripped. When I press the button for delayed start, the 2 hour light turns on. I can hit cancel to stop it.
I think it may be the timer that is messed up.
Any thoughts??
Would it start if you used delayed option?
Not sure. I will try tonight and post the results.
Thanks for replying
It did not start. The 2 hour delay light stayed lit and the no heat dry and lock on lights flashed.
Check both door switches. - The part number for the door switches kit is AP3103581 Gene.
The door is properly latching when you push it closed. You can hear it click and does not open when you pull on it.
I did not mean "door latch" when I said "door switches".
