TheKaister
#1 Posted : Monday, August 30, 2010 5:36:39 PM(UTC)
TheKaister
When i turned on the dual burner on my Maytag Range it lit up for a second and then went out. The inner part hasn't worked since then. The outer ring still works. I thought it was a bad Element and replaced it but that didn't fix the problem. When i took the cooktop off i noticed that the quick connector on the cables for the right side of the cooktop were slightly melted. It looks like there is still connectivity. Any ideas on what to try next. Thanks
#2 Posted : Tuesday, August 31, 2010 2:14:20 AM(UTC)
Replacement parts for MAYTAG MER5765RAB Range - S/c F/s Ele | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/maytag_library/docs/16027247.pdf
Here is a manual
http://www.servicematters.com/maytag_library/docs/16025644.pdf
And a bulletin on switch replacement
http://www.servicematters.com/maytag_library/docs/TDC-0090-B.pdf
Most likely ity is the infinite switch.
But since you see an overheated connector I would disconnect the wires at the switch and check the element for continuity from there.
Be sure to note/mark the wires so you know where the go.
You could also check the switch itself.
Be sure to remove power from the unit when doing this.
I would also disconnect the overheated connector and check/clean it. Since overheating is an indication of a bad connection and it will often fail in the long run.
Guest (4)
