ROCK4200
#1 Posted : Tuesday, July 8, 2008 4:57:50 PM(UTC)
ROCK4200
Hello,
I am having a similar problem with my GE model # GTS22WCMARBB my freezer works but my fridge doesn't. I understand how this fridge works it has a 3 speed evap fan to push air into the fridge duct. I replaced the evap fan back in April of this year do to the motor making noise. Now i opened up to where the circuit board is found out where my fan pins are. We are getting voltage about 12.80 - 13.00V but, when I plug the Evap fan in the fan spinns about 2 -3 revolutions and stops , we also tested out the fan and the fan reads good also I saved my old fan the one that was making noise swap that and it does the same thing. Please help do you think it is the circuit board? Wanted to know before I purchase the part.
Thanks,
Jeff
abadfish66
#2 Posted : Tuesday, July 8, 2008 5:53:33 PM(UTC)
abadfish66
Yep, it's your main control board.
