gottuhaveit
#1 Posted : 15 years ago
gottuhaveit
I believe the freon has leaked out of my freezer as I have pretty much checked everything else that could have stopped the cooling except for the freon. I have a small issue. i just bought a set of ez piercing valves to refill the freon in my system but my compressor has 4 lines coming out of it and I do not know which 2 I need to tap. Is there somewhere I can find a diagram showing what each line is for my freezer or can someone please tell me which line is the high side and which line is the low side. If someone needs a photo of this I can certainly do that as well. Your help would be greatly appreciated and thank you kindly. Don
gottuhaveit
#2 Posted : 15 years ago
gottuhaveit
can I please get a little help here people, thank you
#3 Posted : 15 years ago
The low side is usually 5/16 diameter, others are usually 1/4 inch. The low side is usually has the capillary tube attached to it.
