cadena16
#1 Posted : 17 years ago
cadena16
GE Over the Range (Spacemaker) Microwave Model number JVM 1631BB006
Today my microwave started making a humming sound and then it tripped the fuse and turned off. I am not sure if it heats because it only goes about 20 - 25 seconds before it trips the fuse and turns off. I put an ice cube in there and it did not melt it in the 23 seconds it was on.
Before this I had been having trouble with the turntable. It stopped turning and once in a while it would make a horrible sound. Sounded like it was trying to turn and was stuck.
Please advice.
Thanks!
#2 Posted : 17 years ago
Most likely the problem is a bad capacitor (#49 on the break down diagram), but also it could be a bad diode (# 50 on the break down diagram)and/or magnetron (# 73 on the break down diagram).
You have to check all these parts for continuity.
Here are the break down diagrams for the GE microwave Model JVM1631BB006
