Turbotom
#1 Posted : Wednesday, September 12, 2007 6:33:24 PM(UTC)
Turbotom
Just bought a new motor from APP last week. Tried to install it tonight but I can not figure out the trick to getting the blower fan off of the motor.. Right now I have channel locks on the motor shaft preventing the motor from turing and the tag on the fan cover said to turn the fan clockwise. I guess my fingers are just to weak to turn the fan hard enough. I just can't get a grip on it. I tried holding the fan and turing the motor also, but still can get a good enough grip. Is there any tricks or tips anyone could help me out with? I'm almost to the point where I am going to break the fan off and just buy another one.....
This is my girlfriends dryer and I forgot to grab the model #
Thanks ahead of time for any help
Tom
#2 Posted : Thursday, September 13, 2007 1:25:06 AM(UTC)
Put vice grips, or an adjustable wrench on the blower wheel and an adjustable wrench on the motor shaft ( a pipe wrench works also) Turn motor shaft clockwise(left hand thread) A little impact helps.
If the blower faces forward, put a 1/2 drive socket wrench in the blower and a wrench on the motor and turn blower clockwise.
ApplianceJunk
#3 Posted : Thursday, September 13, 2007 4:31:24 AM(UTC)
ApplianceJunk
Views messages in topic : 2,277
and sometime they just don't come off.
If your replacing the motor along with the fan blade then you can use a hammer to remove it. :)
One big blow with a hammer at the center of the blower wheel and you can bust up the old wheel enough to pull the motor out.
Of coarse you will need a new blower wheel after doing this.
Turbotom
#4 Posted : Thursday, September 13, 2007 5:16:26 AM(UTC)
Turbotom
Thanks for the responce. I was turning the motor shaft the wrong way when I tried to hold the wheel.
So pretty much use the vice grips or the adjustable wrench to hold the blower wheel , and then turn on the motor shaft clockwise.
Turbotom
#5 Posted : Thursday, September 13, 2007 5:19:13 AM(UTC)
Turbotom
The BFH ... nice. I was thinking about doing it but decided to hold off trying to get everything fixed last night.
I'll let you know how it goes
#6 Posted : Friday, September 14, 2007 1:57:34 AM(UTC)
Ninety nine percent of the time, vice grips on the blower will result in successful blower wheel removal.
ApplianceJunk
#7 Posted : Friday, September 14, 2007 4:41:01 AM(UTC)
ApplianceJunk
richappy must be stronger then me. I only have a 95% successful blower wheel removal rate with the vice grips. :p
It's alway's the other 5% that is all the fun anyway, lol.. :)
Turbotom,
You get the job done?
#8 Posted : Friday, September 14, 2007 1:43:34 PM(UTC)
Right on Appliancejunk. There is a certain animal pleasure out of pounding the hell out of the blower wheel, personally I like a sharp hatchet!
I had a lady smile at me while I was pounding a bad pump away from a washer motor, she said now that's a job for a man!!
Turbotom
#9 Posted : Friday, September 14, 2007 7:42:35 PM(UTC)
Turbotom
Apparently I like pounding the hell out of things too. I got it off tonight, but not the way I wanted to. I held the wheel with an adjustable wrench while my girlfriend turn the motor shaft with another wrench. A fin on the wheel cracked. I decided heck for $20 I can get a new one shipped here and proceeded to beat it with the hammer. It was worth it :D even if I could have still used that wheel.
One thing I did learn. Wear gloves while working on dryers! Those clips that hold the motor down can be a pain to get off. When wrenchs slip, hands fly. Metal edges wrecked havoc on my knuckles.
Tom
#10 Posted : Sunday, September 16, 2007 1:50:16 AM(UTC)
I use a long bladed screw driver for the clips, saves on the knuckles.
Guest (7)
