Patchpeach
#1 Posted : Wednesday, August 25, 2010 4:51:20 PM(UTC)
Patchpeach
The "over temp" lite keeps blinking and everytime i go near the unit, it's running.
It's is cooling, but it seems like it's barely cooling just because the freezer won't go below 16 and the fridge is at 34.. the ice in the ice maker is frozen but you can tell it should be colder.
Any thoughts of what could be wrong and how to fix??
I tried the "max cool" button but that doesn't do anything to lower the temperature..
I have upplugged and plugged the unit back in to see if resetting fixes it.. no.
Any ideas?
#2 Posted : Thursday, August 26, 2010 5:00:42 AM(UTC)
Replacement parts for KSSC48FM01 models | AppliancePartsPros.com
Here is a tech sheet. I could not find a FM01 following is for a FMS01.
Please check your model number.
http://www.servicematters.com/docs/wiring/Service%20Sheet%20-%202302865.pdf
Here is a manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/507220676c24d02d85256b5800675172/$FILE/4317326A.pdf
Try to run the diagnostics to see if it will geve you a clue as to the problem.
It could be a defrost problem.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the board is toast.
