Just replaced belt on this unibelt system. Pain in the butt. Anyway, did 3 washes after the belt replacement and now it seems like the tub is leaking. No sure if its the tub or a seal. Eiter way i dont know how to get the tub out. I have the top, the agitator and the bolts out but now i cant figure out how to get the tub out....please help
Remove the front panel and check the water pump (under the motor). - The part number for the water pump is AP3873050 Gene.
