Marine Gunny
#1 Posted : Monday, August 23, 2010 5:22:28 PM(UTC)
Marine Gunny
My wife was recently doing laundry and in between loads the dryer stopped working. Being an electronics technician in the military I started with the most logical players.
I checked out the door switch and the push to start switch with an ohmmeter (both good). I shorted out the wires going to the thermal switch and it still didn't turn on.
We are a military family on a tight budget. Any suggestions on how I can fix this thing myself would be greatly appreciated.
#2 Posted : Tuesday, August 24, 2010 8:15:55 AM(UTC)
Here is a parts breakdown. Closest I could find is TQ0
Replacement parts for WHIRLPOOL RED4400TQ0 29" Electric Dryer | AppliancePartsPros.com
Here is the wiring diagram for the VQ0
http://www.servicematters.com/d...0Sheet%20-%208576793.pdf
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
If power is OK.
Unplug the unit, set the timer to mid scale timed dry and check the BU/BK timer contacts.
Be sure to disconnect at least one side so that you do not read an alternate/parallel circuit path.
If OK
Check the motor windings for continuity.
Marine Gunny
#3 Posted : Wednesday, August 25, 2010 9:05:55 AM(UTC)
Marine Gunny
denman - I cannot thank you enough. I had checked the breaker at the plug and assumed that since I was getting the 120V I'd be getting the 240V. I had also checked the breaker and since it wasn't tripped I had ruled it out. One side was working, the other side was not. I figured that it still would have tripped the breaker.
After a quick run to Menards and $8 later my dryer works again!
Thanks again, much appreciated!
#4 Posted : Thursday, August 26, 2010 5:19:44 AM(UTC)
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
Military Man on a Budget Need Help with Roper (Dryer Repair)
by Marine Gunny 8/23/2010 5:20:29 PM(UTC)
