clpage
#1 Posted : Tuesday, August 24, 2010 5:24:59 AM(UTC)
clpage
After using the cleaning feature on my Electrolux oven now the oven heats very slowly. Takes > 1 hour to get to 300 degrees. Everything else seems to be working. HELP!:(
#2 Posted : Tuesday, August 24, 2010 8:35:54 AM(UTC)
Cannot find any technical data on this unit.
I would check that both oven elements are working.
Often during preheat both elements are used.
clpage
#3 Posted : Tuesday, August 24, 2010 4:35:54 PM(UTC)
clpage
The bottom of the oven heats while preheating, but the top of the oven does not.
#4 Posted : Wednesday, August 25, 2010 1:34:03 AM(UTC)
Put the unit into Broil mode.
Now does the top element work?
If not, unplug the unit pull the Broil (upper) element and check it with a meter. Should be approximately 20 ohms.
Note: It is a good idea to clip something (clothespin etc.) to the wires when you pull them into the oven so that they do not disappear into the back of the unit.
clpage
#5 Posted : Friday, August 27, 2010 2:44:53 AM(UTC)
clpage
No heat at all from the upper element.Can you help me find the part number to replace the upper element for this oven? Thanks!
#6 Posted : Friday, August 27, 2010 3:21:38 AM(UTC)
Your model number does not come up.
If it is a USA model give them a call and they should be able to find it for you
Appliance Parts search by model or part number | AppliancePartsPros.com
If not a USA model call your local Electrolux parts supplier.
You did not say that you checked it with a meter.
It is advisable to do this as it could be that the broil relay on the control board is shot,
Also some units have a hi-limit thermostat that is sometimes just for the broil element.
