Originally Posted by: stinkintoad  APP team:
I think you guys were wrong about the resistance check of the tacho-generator on the motor. The schematic supplied with the washer says the tolerance is 184 +- 7 % ohms, not 105-130. This is measured on pins 5 and 6 according to the chart given on the schematic. I was getting 194 ohms, which is in tolerance.
Just so you know, I have 30 yrs experience working on engines, electrical systems, and electronic control systems. I measured the voltages (with a Fluke 87V), while the connector was attached to the motor, water disconnected, plugged in, and timer turned to 'heavy wash' so the motor would rotate. between leg 1,2,3 to ground I'm getting 160vac-contstant voltage, even if I load up the drum to the point where the motor starts doing it's erratic jerky behaviour like it exhibited during the original problem. The voltage did not drop off, but the motor behaved erratic. The voltages line to line, when measured, were lower-around 60vac, but consistent, even when a high load was put on the motor. I even clamped the drum to make it stop completely and the motor would just stop, spinning slightly on the pulley, every so often doing the erratic behavior.
Do you guys still think it could be a motor problem, even though the controller seemed to be supplying contstant voltage. Would the voltage change if the controller amperage output changed??? Sorry for the misunderstanding, Apparently, I used the wrong service manual and diagram on my previous post. I've alsways suspected a bad control board or speed control board as the culprit, the motor Checks fine , by the information you just supplied. I have attached excerpts from the service manual that I do have, so you can see how the control board fluctuates voltages to the speed control board, based on selection made, and how the speed control board fluctuates voltages to the motor. (these voltages and pins may not match your particular diagram, but I suspect they'll be pretty close). Good Luck, Disconnect the ten pin plug from the speed control board. Measure the resistance between pins 3 & 4 of the ten pin plug. 184 Ohms +/- 7%. Defective speed control board.
Readings other than 184 Ohms +/- 7%. defective motor.
Drive motor tumbles very slowly when the washer is in operation.
Note: Always check wiring to the components.
Note: The control board is the board in the console. The speed control board is the board in the right rear corner.
Measure the voltage between pin (6) of the seven pin plug and neutral. Meter should read: 3 VAC or -163VDC in Max Spin. 35VAC or -30 VDC in Med Spin. 0.2VAC or -12VDC in Low Spin.
Correct readings. defective speed control board.
Incorrect readings. Defective control board.
Drive motor tumbles but does not spin. Display may show F 04.
Program and start the washer in the Drain/Spin Cycle.Disconnect the six & ten pin plugs from the speed control board. Measure the voltage drop between pin 6 of the six pin plug & pins 1, 2 ,6, 9, & 10 of the ten pin plug If between pin 6 (6 pin plug) to pins 1, 2, 6, 9 &10 (10 pin plug) reads 120 VAC. Defective speed control board.
If any other readings besides 120 VAC.
