huckfinn979
#1 Posted : Saturday, August 21, 2010 9:33:28 AM(UTC)
huckfinn979
hello my whirlpool estate electric dryer is takeing two or three times to dry a load of clothes. I checked the heating element and it is glowing red and heating. If you can help me i would appericate it thanks matt
ThatGuy
#2 Posted : Saturday, August 21, 2010 11:10:09 PM(UTC)
ThatGuy
Groups: Expert
United States
Drying is a matter of heat and airflow. Loose either one and it takes forever. I would check your venting. A couple of important rules. Never use plastic vent for dryers. Its not UL approved and its not safe.
Always use a 4 inch vent and 4 inch pipe. You can use either rigid or flexible metal, but try to keep the number of elbows down to a minimum. Each 90 degree elbow is equivalent to five foot of straight pipe. Any pipe run of more than 50 feet will seriously slow down the airflow.
#3 Posted : Tuesday, August 24, 2010 7:00:56 AM(UTC)
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems
