cowboy2296
#1 Posted : Thursday, September 13, 2007 4:51:36 PM(UTC)
cowboy2296
I have an Admiral dryer that is about 1 yr old -last April I moved into a brand new home and now the dryer will dry one maybe two loads and shut down for 20-30 minutes-after that this cycle begins again. one or two loads (and not full capacity loads) then off
I wonder if anyone can tell me the problem since it only started when the dryer was moved to the new home approx 700' total moving distance
#2 Posted : Friday, September 14, 2007 1:52:41 AM(UTC)
Sounds like your motor is overheating and stopping on internal overload switch.
Check motor bearings and look around for a burnt/loose wire to motor.
