ric
#1 Posted : Thursday, September 13, 2007 1:26:09 PM(UTC)
ric
washer is used in the regular fabric cycle usually,it stopped working,does not work in the permanent press cycle either,only the delicate cycle
#2 Posted : Friday, September 14, 2007 1:21:02 AM(UTC)
If motor never runs in regular cycle, you have a open high speed winding in the motor.
ric
#3 Posted : Saturday, September 15, 2007 6:54:58 AM(UTC)
ric
so if nothing happens,water doesnt fill or anything its the motor winding
#4 Posted : Sunday, September 16, 2007 1:25:52 AM(UTC)
With a meter, check the ohms of the high speed winding. Also, push in the motor pin for the high speed winding, it may not be making contact.
Washer only works in delicate cycle (Washer Repair)
by bicycle 6/20/2012 5:25:11 AM(UTC)
