Hotpoint Washer Model VBRX1070W0WW I have researched your site and somewhat determined that I need part # AP2045830. However, before purchasing I need to confirm that this is the faulty part and not just the outer knob. When I set the timer, the knob is supposed to push in and contact, what appears to be a gear to set the time. I have had trouble with the knob sometimes not making contact and just turning without actually setting the timer. Is this due to the timer or could it just be the outer knob that is worn? Thank you Ken Benson
