stewfraser
#1 Posted : Tuesday, July 1, 2008 8:24:18 PM(UTC)
stewfraser
The refrigerator is set at 40 degrees, the top of it is OK but the bottom in the meat cabinet is running at 27 degrees. I have had the temperature regulator changed but this did not help. The internal selector for the bottom cabinets is set at the cheese (warmest) position.
Help please.....
#2 Posted : Wednesday, July 2, 2008 6:03:02 PM(UTC)
I believe you can find the solution for this problem in this Maytag Technical Bulletin.
