Hi, My My microwave has an f3 message. I unpluged it and when it asked me to set the clock , Th keypad doesn't work... after a minute or so it beeps and F3 appears. Should a new keypad fix it? is it easy to replace myself. Thank you!
Rick
Hi Rick, "F3" error code shows the key pad is shorted. So replacing th key pad should solve the problem. - The part number for the key panel is AP2026167 Here are the break down diagrams for the GE microwave Model JVM1660SB001Gene.
